do you think it low compression did a static test had 140 and the cam timming intake closes at 46 abdc and will the rv tipe cam give too high compression
You need to divorce the concept of ratio from pressure. Pressure has a loose relationship to ratio that moves around with temperature, atmospheric pressure, humidity, throttle opening, engine speed, etc. The concept of ratio is a mathematically based upon the volume ratios of the swept cylinder plus what's above the piston divided by the volumes above the piston. The above piston volumes include what the shape of the piston crown contributes.
The compresion ratio comes in at mimimum two flavors that the Static Compression Ratio (SCR) and the Dynamic Compression Ratio (DCR).
The SCR is simply the volume swept by the piston which is the bore diameter squared times .7854 times the stroke. The volumes above the the piston include what ever the piston crown shape affects domes remove where dishes add volume. The clearance between the piston at TDC and the block deck production Chevy is about .025 inch times the bore area plus the gasket volume (gaskets are not round so the true volume is usually a bit more than that calculated for diameter) plus the combustion chamber volume.
The DCR is the effect on the SCR that the seating of the intake valve has on stroke. The later the intake valve seats the shorted the stroke looks to the compression ratio. This is a complicated formula that is the same one used for comparing effects of different rod lengths. There are a great many DCR calculators on the web Keith Black has a good and easy to use one. Essentially what this is about is computing the SCR needed to recover the bottom end torque lost to a late closing intake. When the intake is held off its seat by the cam, at RPMs lower than where the intake manifold is building enough speed in the mixture to overcome the reverse pressure in the chamber made by the rising piston. The mixture that entered earlier in the intake cycle is pumped back into the intake. This reduces the molecular density inside the cylinder after the valve closes. This results in a loss of power on the bottom end and it pushes the torque peak as well as the horespower peak to higher RPMs and closer to each other at the RPMs where the peaks occur. The problem with rampy cams of moderate lift is that they hold the intake slightly open and leaking for a long time and the lift is such that it doesn't take advantage of the high port flow heads like the Vortec. The result is you're not getting the power you paid good money for in terms of the parts.
The minimum DCR to shoot for is not less than 8 to 1 and that would be with a cast iron head that burns regular 87 octane unleaded. This cam really doesn't get on the seat till 75 degrees after bottom center. Giving the cam credit for no reverse flow when the valve is held .006 inch off the seat that means that effective closure is 70 degrees after BDC, this drives out a wheezy DCR of 7.1 which is way low. This I calculate from a SCR 8.96 to 1 which is a guesstimate based on your data from which you claim a 9 to 1 ratio.
Unfortunatley without serious work to the engine, it is difficult to get the DCR up where it needs to be for this cam. Guess I should have run these numbers sooner, You've either got to get deep in this motor to change pistons and zero deck the block to get up around 8.2 to 1 DCR with 64 cc chambers or dial this cam way back.
Actually if you read the fine print Sumit says this cam is for a blower or laughing gas motor, and you can see that in the huge exhaust lift and timing. So this cam in addition to the late closing intake valve is more likely than not over-scavenging the exhaust as it is looking for a whole lot of exhaust resulting from a source of boost. This also is a tough problem to solve when it happens, without changing the cam to something milder.
In any case no matter what cam you use the 193 head is going to stand in the way of getting upper end power from the engine. But your current cam is rated for 3000 to 6000 RPM, the 193 heads are all out of breath by 4000-4300. So just about the time your getting up on this cam the heads are done.
