Vortec heads with stock springs limit your lift to .475-.480. With what you want, I would go with a Performer intake and a 600 cfm carb. For a camshaft, I'd go with a XE262 or you could follow the 330hp 350 from GM Performance. Here is their specs: complete crate engine in the form of a 350 cubic inch HO with approximately 9.1:1 compression, 330 horsepower at 5000 rpm and 380 ft./lbs. of torque at 3800 rpm. These 4-bolt main engines have a recommended max RPM of 5500. Dressed to impress with chrome valve covers and front timing cover these engines will look great between the fenders of your favorite street rod, muscle car or grass roots racer. These 350 HO are not intended for marine use and should only be used in 1979 and earlier pre-emissions street vehicles or any year off road vehicles. Parts used in this engine assemblies are 4-bolt main 1-piece rear main seal blocks, nodular cast iron crankshafts, powdered metal connecting rods, Dished cast aluminum pistons. Installed camshafts are hydraulic flat tappet with .435 in. intake lift and .460 in exhaust lift with duration at .050 in. for intake is 212 and 222 for exhaust with a 112.5 lobe centerline. Standard morse link timing chains are installed. Cylinder heads are Vortec cast iron style with 64cc chambers; 170cc intake runners with 1.94 in. intake valves and 1.50 in. exhaust valves. Stamped steel self-aligning rocker arms are used for reliability. Aluminum dual plane with EGR capability Vortec style intake manifold with a Holley 600 CFM vacuum secondary with electric choke help feed the engines. Spark plugs, HEI distributors, and spark plug wires are included. Cast iron long style water pumps with standard "V" belt rotation threaded for 79'-89' power steering pump brackets. Standard 8 in. balancer and 12 3/4 in. flexplates, along with chrome air cleaner, and standard cast aluminum thermostat housings with driver side hose connection and a 180 degree thermostat. This kit also includes the oil filter, oil filter adapter, pcv valve, pcv hose, oil dipstick, and tube. Does not include starter, fuel pump, fuel pump push rod or the fuel pump adapter plate.
I went with a little bigger camshaft since you got more compression. With about 350hp in 220lb car, that would be a fun ride. Good luck
