Hey fellas,
First let me start off by saying that I am NOT looking for a COMP/Lunati cam. I just wiped out a Lunati cam due to lifter failure, and I don't like anything that I've heard about COMP lately. I want nothing to do with crappy cam cores or junk offshore lifters. I've been looking at Crower, since they actually carry Hylift Johnson lifters.
Since I wiped out this Lunati cam, I'm looking for something that works with my current setup so I can just slap it in. I'm not looking for a mechanical flat tappet (would need to send heads to get machined for threaded studs) and I don't want a roller (I don't want to spend more money replacing my brand new timing set, springs, etc). I'm just looking for a quality flat tappet cam/lifter setup that will last. The TRW cam I pulled out was in there for 25+ years. Anyway!
Here's my build:
355 (.030 over) 10:1
Stock cast crank
SCAT Forged 5.7" I Beam Rods
Sealed Power flat top pistons w/ 4 valve reliefs (+6.90cc)
Melling 10552 HV Oil Pump
Cloyes C-3023x Heavy Duty Double Roller Timing Set
Stock Iron 906 Vortec Heads
FelPro 7733SH1 .016" Steel shim head gaskets
LS6 Valve Springs 12499224
COMP 787-16 Retainers
COMP 1.52 Steel stamped self aligning roller tip rockers
Edelbrock Performer RPM Intake
Holley 4160 600cfm vac. secondary carb
Stock GM HEI
TH400 w/ 9.5" FTI 2400-2600 stall
3.42 rear gears
Full weight '73 Camaro with power brakes, so I would like decent manifold vacuum. Car is street driven, but I beat the **** out of it, so it WILL see 6000 RPM's.
Just to give you an idea, this is the Lunati cam that I chose (and it felt pretty damn strong until it wiped out):
227/233 dur @ .050 / .489/.504 lift 110LSA / 106 CL
I've been loking at Crower, Howards, and Isky. What do you guys think?
Thanks!
Here's my build:
Stock cast crank
Stock GM HEI
3.42 rear gears
Thanks!
