Flat tappet??
If it is, it is junk if it is used...unless you want to send it in for a regrind. Cores are in short supply at the moment, so if you are planning a build you might want to hang on to it for that reason.
"CWC" is Campbell-Wyant-Cannon, the foundry in Michigan that cast the core and ground the blank. They grind the cataloged cams for a lot of different companies to put their own name on it.
Numbers between lobes are just core identifiers, you can't get an spec info off those numbers.
The "201760" is probably somebodys part number, but who knows whose it is? Could be an existing company, or one that is no longer in business or no longer sells camshafts.
