where in the hell do you route that cable to the mirror?? i tried in front of the window and under it and it gets caught by the window on the way down every time. i dont see any clamps screamin at me to stick it in one so i dont know. i dont have the thing that holds it to the inside of the door anyway. help me ob1 your my only hope
Bull, not sure on the routing, I'll go out tomorrow and look for you, but I do have the little metal thing the cable goes into on the doorpanel. Not sure how the hell you got a cable without one because that cable pissed me off to the point I ripped it out of the door, broke the mirror and cut the cable after it was out to get the frikin mirror off in my first Camaro.
I do beleive the cable goes above the window follows around the inside of the door to the mirror. Don't remember, but will look in a few hours and send you an e-mail. If you want that little metal thing let me know, I don't need it.
HK
HK! thanks, i posted this at nastyZ28.com and the answer i got was there is a clip on the inside of the inside of the door that routes the cable to the front, then it goes under the window so i will look better to find it and stick it in there. i have the joystick part that the cables end in, i will need the part that holds that onto the inside door panel. i will definitely be getting that part if you have it. i will know in a few what's up after i find that clip and get the door panel on. i have to start moving today, but first i have to fix the front garage door where im going and add a back door to the hole that's there too. i have to be out on the 31 and that is a friday, hope my landlord lets me move next sat, but i'll be doin most of it at night. suck!
anyway, just looked. there IS a clip on the inside of the outside door skin. put the cables in it and now it works. also HK, thanks, but i just found that little metal bracket in a plastic baggie!!!!!!! im all set, but i think it will have to wait till dark, jesus it's rainin out there!!! maybe i'll have to forget workin outside. i also wanted to plant two 4x4 posts near enough to my garage to string a tarp across to protect the camaro. i have a feeling the windshield leaks, and i dont want water on my new carpet or worse, under the new felt. :(
[ January 26, 2003: Message edited by: bullheimer ]</p>
