You have the heads from an L31 vortec 5700? Or some other "vortec heads"?
With stock springs and valve train parts, the stock L31 heads are limited to somewhere between 0.460" and 0.480" total lift. It varies with the castings and parts and must be measured. The first cam might work with stock valve springs. The second one will at a minimum require alternate "beehive" valve springs. And if the coils bind on the stock springs with the first cam, it will also need these alternate springs.
If it's mainly a street driven vehicle, the first cam is probably going to be a better choice. If you're going to run it down the drag strip more than a few times, the second will make more power, but may not be as good at lower RPMs. You'll probably want a higher stall speed for the torque converter with the second cam.
