Hello guys I am making a new post here and apologize for the long post as some know I have been having an issue with my 350 Dart shp build that I can't figure out what the problem is and I am thinking that the camshaft I have just might not be working for some reason with this build as everything else has been checked and checks out ok and I can't seem to get a 600 Holley vacuum secondary carb or any carb yet to work right on this build and the others I have tried and it was the same on previous 377 SHP build but slightly different but not by much.Nothing carb wise had been normal working and being able to be adjusted.
It seems to have air and fuel distribution issues and and the fuel is falling out of the mixture and puddling in the intake and some other issues in the combustion process.
I had a Mike Jones custom before the cam and intake swap and any carb I put on it I could get to work with just minor tuning like normal on the previous 377 and it ran fine wtih a victor jr intake and its specs were
276/280 228/[email protected] 510/510 lift 106/112 lobe separation angle 54 degrees overlap seat to seat
Seat to seat IO 32 IC 64 EO 78 EC 22
@50 IO 8 IC 40 EO 54 EC -2
No exhaust heat crossover had ever been used in all my past builds including this one so I know that a carb needs heat in the cold months but I never had this mystery problem I have now in over twenty plus years of small block chevy builds. Even during the warm months I have had the same problem.
I had a 350 build in the past that had 200cc RHS cast iron heads with a high rise dual plane intake with 9:1 compression and below is three cams I had in that build and all three worked just fine without me having the current problem I am having. That build got the cylinder heads changed out to a set of Dart 180cc SHP aluminum heads and had the Lunati voodoo hydraulic 270/278 219/[email protected] 515/530 lift cam as its final one before I sold it in 2018 and went to my 377 which I swapped out that short block to my current 350 build.
I know the cams used with that previous 350 build with the RHS heads then over to the Dart 180cc SHP heads build were not perfect especially the Crane hydraulic roller and could have a slight bit more compression with them but they all ran good still.
I won't post anymore history on that part and hope this post is not confusing and sorry for all the info but I need to know if there is somebody that can look at these cam specs and who has way more knowledge then what I do on them and if you can see anything by the opening and closing specs of them that would indicate a problem of my current grind compared to previous grinds I have used in the past that worked just fine with an almost identical setup. I know the opening and closing events of a camshaft if not grounded right could have a negative effect on how the engine would run.
I know the basic tech such as lobe separation angles and the specs of duration and what I am looking at and also the effects of wider versus tighter lobe angles and the effects of overlap. What I am looking for is a more advanced knowledge of looking at the opening and closing degree numbers and being able to get an idea if something would not work right such as the intake valve being open to long or to little and the same thing in relation with the exhaust opening and closing numbers.
I know things work in relation to the opening and closing points and it can affect certain areas of the cam in relation how it will work with the engine such as the whole combustion process and can effect the engine build.
Current cam Mike Jones custom grind hydraulic roller.
268/272 220/[email protected] 510/510 lift 110/114 lobe separation angle 42 degrees of overlap seat to seat.
Seat to seat IO 24 IC 64 EO 78 EC 14
@50 IO 0 IC 40 E0 50 EC -6
Previous 350 build camshafts used in it.
Lunati voodoo hydraulic roller cam
270/278 219/[email protected] 515/530 lift 106/112 lobe separation angle 50 degrees of overlap seat to seat
Seat to seat IO 29 IC 61 EO 77 EC 21
@50 IO 3.5 IC 35.5 EO 51.5 EC -4.5
262/270 211/[email protected] 500/515 lift 106/112 lobe separation angle 42 degrees overlap seat to seat
Seat to seat IO 25 IC 57 EO 73 EC 17
@50 IO -0.5 IC 31.5 EO 47.5 EC -8.5
Crane power max hydraulic roller
283/291 222/[email protected] 5??/5?? lift (can't remember exact lift) 108/112 lobe separation angle 63 degrees overlap
seat to seat IO 35.5 IC 69.5 EO 81.5 EC 29.5
@50 IO 3 IC 39 EO 51 EC -1
Thanks guys and hope to hear from some of the more knowledgeable guys on here. I have tried looking up stuff on google but I can't find much.
