Hello everyone. I have finally found a block and heads. They are currently at the machine shop. The block is a 454, 4 bolt that will eventually be machined for a 496 forged rotating assembly. Heads are older 6055 aluminum Edelbrock. It will go in to a 1970 Chevelle, 4 speed Muncie (with plans for a tremec in the future) 4:10, 12 bolt
The shop and owner have been around since the 70s. The owner is very knowledgeable and has assembled hundreds of engines. However, I was surprised by a conversation we had at the shop. He was speaking highly of the big mutha thumper comp cam. Quite honestly I have not read much good on this line other than “it sounds good”. It is nice to have a nice sound but I’m more concerned on the performance within monetary reason. That’s why I will be keeping the heads that I mentioned. Anyway, what do you guys think? Is that cam good? If not what would you guys have me look at?
I believe the cam is 108 LSA. I guess that’s where the rough idle comes from. I am concerned with vacuum on the brakes. I understand this may also cause fumes in the cabin? Does that sound right?
This build will happen as money becomes available. But my first step is to get the heads set up so I need to know what cam to use.
Thanks for the help, comments and suggestions.
