83montess, here's the page with the info on the Lunati #60111 cam.
Product Description
Hydraulic roller, fair idle. Strong power increase in mildly modified engines with excellent throttle response. Will work with stock converter in 383 and up size engines or 2200 RPM stall speed converter in 305-350 cubic inch engines. Likes 3.23-3.73 rear gears. Also the largest cam for inboard/outboard marine applications.
* Advertised Duration (Int/Exh): 270/278
* Duration @ .050 (Int/Exh): 219/227
* Gross Valve Lift (Int/Exh): .515/.530
* LSA/ICL: 112/106
* Valve Lash (Int/Exh): Hyd/Hyd
* RPM Range: 1800-5800
* Includes: Cam Only
Part Number: 60111
There's more info on this webpage:
http://www.lunatipower.com/Product.aspx?id=1988
Hope this helps,
Ed
When the
drops the
stops!
Check out my website at:
