matt167 said:
'98-'2003 ( IIRC ) Ford made EV Rangers... you may be able to get the parts to build 1
as for 4 motors driving.. gonna have to adapt somthing like a suburu rear suspension and tie the CV axles into the motors.. Tbird IRS fits if you can work with a driveshaft and 1 motor in the rear
You're right, Ford did make EV Rangers from 1998 to 2002 and leased them through about 2004. But that's a standard electric vehicle, and I want to make more of a hotrod.
I don't care about range or freeway speeds. But I want to put an electric motor on each wheel, for true four-wheel drive. Then I can do interesting things, like have wheels turning in different directions. Front-wheel steering will also be independent, so I can do "snow plow" panic stops like a beginning skier.
The front end turns out to be easier to hook up to electric motors. The rear end with its solid axle has me a little puzzled. As you say, maybe a Subaru rear suspension might work, coupling the CV axles into the motor shafts.
Or I might just replace the differential with an open frame, top and bottom, that bolts onto the axle casing on the right and left. That could also be my motor mounts. I would need to cut back the axle casing about a foot on each side.
Thanks for the ideas.
