1 - 16 of 16 Posts
okay so i cut out rust hole, replaced it with new metal...its all strong and well and all that but i accidentally blew a small hole in the seam with the MIG and dont want to try to fill it or something and make it even worse. can i just spread kitty hair over the area like i was going to originally but just have it gap the small hole?
its waterproof and its also got the fiberglass strands in it so i figure it should be just fine. this is no show car....its more like i desperately need to finish the body on my mustang so i have a car to drive...period....
what do you guys think?
okay, in the top left corner....
my digital camera has no batteries right now so i had to take it with my cell phone...it sucks but you can get an idea of the size of the hole....i haven't completely finished grinding it down but almost.
yeah...i would too if i looked at it "on paper" but im still not exactly a jedi master with the welder and the hole used to be even smaller until i tried to weld it then it just got bigger instead of smaller....i just dont wanna wreck it even worse.
i think im gonna see how the kitty hair works out. ive still got other patches i need to do as well.
Duraglass is short strand glass, probably like kitty hair.We used stuff call tiger hair back in the old days. Real long strand glass, hard to get all the air out of it. After you ground it there were a lot of pockets. Usg makes it I think.
My welding really kinda sucks, so I usually back my patches with fiberglass netting (the fine criss-crossed stuff..not the bigger helter-skelter stuff), using the normal liquid resin, after I weld in the patch panel. My stuff seems to hold together pretty well. A friend of mine (who had a body shop) once told me that it's real important to seal the seem from behind (if you can get there), as oxidation can attack from behind the patch, even more than the front. My method forms quite a barrier from behind. I usually put a second coat of resin on it the next day, after I run a coarse piece of sand paper over it to knock down any stray stiff fiberglass hairs. I use the small disposable chip brushes to work the resin & fiberglass. The kitty hair would work O.K. too, I would imagine, but why not seal the whole patch? I found that it also give the area a lot more strength, especially if the metal is already stressed & thin. This is only my opinion. I'm not involved with high level stuff. Life is too short. Good luck...Greg
you can get to the back side of that repair....seal it there
first choice: 2 part panel adhesive on a second inside patch, cover all the patch with enough adhesive that it oozes thru the burn thru......sand when cured and start filler
second choice, Duraglas from the backside with a spreader onto a roughly sanded surface till it oozes thru, epoxy on the duraglas to seal it
only a patch in that area didn't get all the rust and the welding hurt the surrounding metal, sand blast all the lower inside area and epoxy,
Problem Child,Hard Case
Use a piece of copper to back up the hole to weld. Slit a piece of copper tube and flatten the slit end,cut it off for a "handle" as long as you like back up from the slit end. Back up the hole with it and spot weld it up. Weld from the existing weld material back into the car metal with a longer stick out of the wire with quick spots is another way. The weld bead will absorb most of the heat and melt into the car metal without burning that up.
The short strand filler will be fine as your just filling a hole,not rebuilding structure.
1 - 16 of 16 Posts
