For the Rat/Shoestring project I'd like to ditch the F-150 power brake unit because it is so huge and difficult to mount inconspicuously. I happen to have a much smaller PB unit from an old Mazda pickup truck. In doing a forum search Willys noted that one should only use a Master or PB unit from a vehicle of roughly the same weight and that it was preferable to use the entire system if possible (rather than mixing and matching components.)
Regarding weight, I am guessing that the rat, even with a 351 & C6, will be pretty close to the weight of the Mazda. I would, however, like to use the combo valve from the F-150 since it would have the correct metering and proportioning already dialed in - and it might be different than the Mazda combo valve.
Anyone see a huge problem with using the Mazda PB unit and/or the F-150 combo valve? And just to be clear, the Mazda had discs in front and drums in the read just like the F-150.
Dewey
Dewey
