Long story short I had a long block 350 (sbc) built for me, rather stock rotating assembly and a "slightly better than average" set of aluminium heads and a thumpr cam (smallest). I put an edelbrock rpm air gap intake on it and a 650 proform holley double pumper.
I got it decently tuned for a beginner (buying a wideband o2 sensor soon to really dial in the jetting and accelerator pump cams) but I still get really REALLY bad bucking at cruise speeds. I know that's kind of to be expected with a thumpr cam, and also my rear-end is currently only running ~2.77 ratio. (going 4.11 in 3 months, can't wait!)
Anyway, my question is, can I cure a bit of that bucking with some fine tuning of my timing advance curve? I got a nice little msd billet style dizzy that is currently set to 18* initial and 18* mechanical for a total of 36* at about 3k.
The vacuum advance is currently hooked up to a ported source instead of full because letting my idle depend on my limited manifold vacuum (getting about 9psi) was causing the car to die all the time. Anyway it drives great other than the cruise surging\bucking, so I'm just hoping and I can smooth that a tiny bit with some knowledge on how the timing advance is affecting my cruising performance.
Thanks!
Thanks!
