Thanks guys, I just came from vacation, bought myself a tester and measured voltage betwen coil and battery ground with key on . Nothing there so I was following wires and they both go to starter solenoid trough harness where they are probably spliced. When I pulled on wires I was able to get 12 V reading for a moment and then 5.0, 5.7V but was never able to get 12V again . Tomorrow I will put car on stands so I can open that harness and see if I can see that resistor wire from ignition switch and see if it is weakened or why is giving only 5 V.( I think there should sbe only 9V with key on so point will not burn with 12 V )
If resistor wire is bad, is there a place to buy it, local parts store guys have no idea what I am asking them for.
Is it okay to use just regular wires and put in line resistor . Where should it be ? Between ign and + terminal ?
Does anyone knows where I can get wiring diagram for 69 Olds Cutlass or similar car ? Manual has nothing on ignition .
Thanks,
