ok, after the other carb thread I'm having to rethink everthing I thought I knew about carbs. Please bear with my questions and help me learn more.
Changing from a 305 to a 350, will probably be nothing more than stepping up the jet size.
That is what I would have also said about three days ago but... now it seems like a 350 will have better velocity & better booster signal and in effect
more fuel with be drawn thru resulting in the need for
smaller jets. ??!!? ok, whatever.
Also in regards to a mild low compression engine needing a small carb is also what I would have said but... now it seems that a larger carb will raise cylinder pressure due to more complete filing of the cylinder...and raised cylinder pressure, as we all know, raises HP at least until detonation occurs.
So a low compression engine needs a larger carb than a high compression engine all other things being equal!!?
I don't know which emonicon best explains it>
:nono:
