1 - 7 of 7 Posts
I am changing out my Ede 750/manual choke with a BG Speed Demon 750/electric choke.
My question is: How do I "by-pass" the choke function? Texas heat, there is no need for one. Is it just easier to remove the butterfly and choke assy?
Did I make a good decision in changing the Ede 1407 to the Speed Demon 750 on my 396/375?
Thanks in advance for any help!
I suppose propping it open with a broom handle is not the help you're looking for?
Actually the choke bi-metal spring should be adjustable in that the plastic housing can be rotated and secured with its screws, so probably the simplest way is to turn the plastic housing till the choke is fully open and tighten it there. Then just don't hook up the electrical circuit that heats it. Or put a switch in that circuit so you can have it in the winter if your area of Texas like El Paso gets cold a few days of the year.
Awesome. Thanks!! So, it's not a major tasking. Sheeew! I've had a lot of problems with the Ede 1407 boiling out and not wanting to start back up. BBC underneath 68 Camaro hood. Doesn't help that the fuel bowls are under carb against the intake. I just figured that the side-hung bowls, larger on Demon, would put this to a halt.
Houston is HOT and muggy ALL THE TIME!!!
heat shields
Do you have a thermal break spacer under the carb? Edelbrock used to have one that wasn't much more than a triple gasket thickness - maybe 3/8 inch thick.
They also had a stainless "heat shield" that placed a line of sight thin metal 'shade" in the way of direct radiation from the manifold to the carb bowls.
Both of the devices work well at stopping boil out. They actually duplicate some of the GM factory pieces used on some high perf engines.
At this point, and if that replacement is an older Barry Grant version carb, I might be reluctant to use it to replace that 1407. BG went out of business a couple years ago with the new Demons being made by someone else - do the old ones have parts support.
With the 1407, they absolutely need a spacer or other heat shield between the hot intake (does yours have a 'heat riser'?) and the carb. I changed my 1" aluminum for a 1" phenolic this year and no longer have the boil out I had before. There are several also that have an aluminum shield as well (Mr Gasket, and others)
When I was at the fall Parts Peddler show in Syracuse; there was a guy selling a carb heat shield. It was a thin plastic honeycomb with stainless or aluminum sheet on the top and bottom. He had em for every domestic carb config you can imagine, in 4 hole and open designs. Cool Carb Technologies was the name of the company. They were a bit spendy; but for a situation where underhood space is minimal; I'd not even think twice. One of my friends has one under his Dominator; seems to work great.
http://www.coolcarb.com/order-products.html
Order Products -
I saw those as well and might have considered one had I not just put the phenolic piece under my carb. From what I could see, they use a piece of calcium silicate insulator in the aluminum sandwich - not a new product, but seldom seen ($35 and up at the show) and do work fairly well
1 - 7 of 7 Posts
