carbs and cams
The problem is Mike doesnt like his cam and he wants one with a little more bottom end. He was looking at Summits 1100 cam and I recommended he go with the 1102 instead. Its about 10 degrees smaller on both sides than the one he has now, and with a smaller carb.
NP benwantland, I just thought maybe you didnt catch all that was going on here.
For myself, Ive always been a Ford man, and on 302's, even well warmed up ones, Ive never ran more than a 500 CFM on them.
I also ran a 351 W with Twisted wedge heads and other goodies with my old 390 double pumper racing carb on the street. Nasty bottom end and still pull up ove 7000.
Athought just occured to me.
Mike, what kind of ignition timing are you running? If you have a timing light, try bumping your initial advance up to 12 degrees, and see what that does. I wouldnt go any further than that though, without testing it one degree at a time.
If you set the timing at stock which is about 8 degrees, that could be a lot of your problem. I used to run a minimum of 10 degrees initial with my old 302 Fords on the street. Sometimes a lot more. It all depended on what the engine could handle.
Try playing with your ignition timing some and see what happens.
Something thats always befuddled me is that low compression engines always seemed to like more initial advance than higher copression engines. I know it all has to do with burn time etc, but running lower compression, you run lower octane fuel, which is less resistant to ignition than higher test fuels. Go figure. Guess I need to discuss that one with a petrolium engineer.
Which brings up another point, if you are running higher octane gas on the premis that it will boost your power, it wont. You dont need to run any higher octane than what your engine requires. Running radically higher octane, can infact rob you of power, due to the higher resistance to combustion.
benwantland, I thank you for your kind comments on my er ah um knowledge.
