Just installed a rebuilt holley 4160 600cfm on a F351 Windsor. The engine runs lousy at idle and at low rpm. It runs GREAT above about 2000-2500.
I have also:
1) Pulled the manifolds off and done a compressions test - all 130-135 psi
2) Replaced the rotor, cap, plugs, and wires.
3) Double-checked the timing to 10 BTDC
My question is this...
My carb came with a gasket with 4 holes which match the bottom of the carb. My edelbrock manifold only has 2 large rectangles for openings. The intake ate the centers of the gasket, and now all I have is the square and a small strip running fore and aft down the center of the two openings..
The carb has small channels machined in to it's base. I am wondering if the lack of a gasket between the primaries and the secondaries has got it all messed up?
The engine 1) idles rough, 2) will not start when warm unless you crack the throttle while cranking (or advance it and then close it prior to cranking), 3) hesitates and almost quits at low rpm when the throttle is barely opened, 4) idles very very high (like 1600) after a 3-4 minute WOT run, and in general runs like crap unless it's WFO. I feel as tho I'm driving a funny car....only it's a boat.
I can feel and hear the secondaries as they open and close, the linkage is free and clear, and my fuel is new and clean.
ANy suggestions?
I have also:
ANy suggestions?
