Hello everyone,
I have a 383 stroker with an Edelbrock 750 carb, vortec heads 9.3 compression xe274h cam rpm air gap intake, davis dui ignition. It was jetted 2 stages leaner and It was running fine when I put it away for the winter. I checked the plugs and they where all a nice tan. I rebuild the front suspension and now about 2 months later its running like a dog. Its running rich and one side is running richer. I adjusted both of the idle mixture screws 1 1/2 turns out, I have played around with the timing a little and it didn't seem to help much.
Its almost like it needs to be re jetted but it was running fine when I put it away for the winter????? I don't have much experience with carbs and timing so any help would be appreciated.
I also checked the rods and springs to make sure they where the same and they were, but I did notice some black soot on one, the side that is running richer.
Thanks
Jordon
Thanks
Jordon
