1 - 6 of 6 Posts
More machine than man
I got to looking at things after I got the intake (Edlebrock 7116) mounted to my factory Vortec heads. The intake has 8 bolts in total, but the bolts are all around the front and back of the intake, no bolts in the middle where the carb is located. I am concerned that using a carb lift plate to lift the motor back in the truck is going to warp the intake and cause leaks. Am I being paranoid?
Well I'd be more concerned with the 4 bolts that hold the carb to the intake, and those have always held for me. If 4 little 5/16" bolts will hold a motor, then I doubt the intake will move with eight 3/8" bolts. There's plenty of metal to keep it from warping, unless you hung it from the plate for years of storage.
Good threads ?
I've seen too many aluminum intakes with bad partially stripped holes. I have a box of various lift eyes and an adjustable crank type lift bar and I use all 4 chains. , Usually fasten the lift hooks, eyes, etc. to the heads, accessory monting holes with 4 3/8 bolts and washers, plenty of engagement and enough washers so you don't bend your bolts.
WFO
After I got a look at my Edelbrock Vortec intake and my 062 heads, I wondered the same thing. I decided against it, I'm going to use the lift brackets from an earlier SBC bolted to the accessory holes on the ends of the heads. Bolts and washers through a chain into the ends of the heads would work just as well, just don't use bolts that you are going to use elsewhere- they tend to get bent.
my KARMA ran over my DOGMA
Call me crazy,,,maybe
My edelbrock eps vortec (2716) on my 383 along with the 700R4 trans attached. All by the 1/4" flat steel intake plate and four grade 8 bolts, 6 latteral lines on the bolt head. Light torx on them 10 ft/lbs maybe
The picker would go just high enough to clear my rad support in the C10:sweat:
Not a problem, but enter at your own risk.
1 - 6 of 6 Posts
