I need a good recommendation far a carb on a Ford 460 engine. The engine is out of a 77 Lincoln Mark V and is going into a 78 F250 with a 4 speed trans. The motor is all stock with 8:0-8:5 compression, except for the double roller timing chain I put in at zero degrees up. The 460 has to only turn a alternator and a power steering pump, this is two less accessories to turn when it was in the Lincoln. I live at a elevation of 5500 feet and don't need as much cfm as per say sea level. The truck is going to be pulling a twin axle 18" flatbed trailer everyday around town(work truck). I would like to get the best milage possible but on the other hand I will need the power at times. The stock carb was a 600 cfm Ford Motorcraft 4350 four barrel spread bore carb(junk). I have a adapter plate to fits a standard four barrel Holley or Edelbrock carb on the stock spread bore intake. I was thinking maybe a 650 vac sec Holley with a electric choke or would a 750 Holley or Edelbrock be better or too much? Any suggestions would be appreciated.
