Do you mean put a screw through the scoop into the adapter? How would I take it off again since the adapter is held down by the nut inside the scoop?Self drilling sheet metal screw would fix that in 3 seconds
I got annoyed with it and just got a velocity stack instead. Atleast now it doesn’t turn 🙄This is quite common issue with these scoops. On a roadster i used to own, two thin rods that I fabricated a bracket from the scoop to the rear manifold bolts. Very secure and don't have to worry about it coming loose turning or flying off at speed.
