Hey there all fellow enthusiasts.
I joined this because i need a little help with a project of mine.
I recently converted a rebuilt 305 from carb to TBI. The 305 has had a mild RV cam installed as well as an edelbrock Performer intake and Comp roller tip Rocker arms. All else is stock. I currently have the engine running very well with the TBI system and it definatly makes more power over the entire RPM range. However it seems to suck more fuel than it should. While there could be a few differnt problems im wondering if the cam is producing a lower than normal vaccume reading for the MAP sensor and as a result the ECM is feeding more fuel than nessisary. There are several other possabilities such as a cold O2 sensor as well as a faulty pressure regulator that i have to look at as well but the vaccume question poses more of a concern in that i am planning to build a 350 with a bit more of an agressive cam in it. ie. even lower vaccume.
I will provide photos soon.
