91 GMC Sonoma
Unfortunately, I don't have a whole bunch of info on engine or cam specs. Supposedly it is a 93 nitrous build has H beam rods and forged pistons. Compression ration is unknown and cam specs are unknown.
400 SBC
Brawler 750 cfm race carb (no choke mechanical secondaries)
6AL and 8570 distributor w/mechanical advance. Msd blaster 2 coil. Set to 18* idle and 34-36 ish on the advance.
14-16hg in park/neutral around 9-11 in drive.
Currently running stock jetting other than I have changed IFR from 33 to 28.
74/84 mains. 4.5pv. I'll be changing the IFR to 31 as the 28 are affecting cruise too much causing low load low speed to go into 15's and some surging. Part throttle is slightly rich as well. 12-13 on the afr under medium load.
The problem I am having is that the truck seems to be really strong and right on at wot (12.8-13.2) until it gets up to 190 and above. Once the engine is run hard a couple times, it seems to go really rich at wot, off the scale on the wideband and if I let off it wants to stall. I assume it's flooding at some point, dumping raw fuel in. Plugs also indicate the same.
I assume I should start with reducing mains but I am a EFI minded person so I want to get input from the carb gurus.
TIA!
400 SBC
TIA!
