Moving to Basics forum... The Introduction forum is not for surveys and tech questions.
I payed $500 for it. Someone put a four barrel on it and The body work doesn’t bother me much . The only thing I’ll have to pay for is the machining since the machine shop I have access to is a fabrication shop at the wood mill I work at we have a magnaflux we use for the chip heads but I can’t clean the block bore it or plain it at work for free. .. as far as rust goes that’s not just on a quarter panel. I have no rust on the frame and some rust rot on the back window.You won't want to hear it...but the cost of restoring it, even if you can do all the body and paint work yourself will be 5 times what it'll ever be worth finished....because it is a more-door, lowest rung on the restoration desirables ladder. A big block car would have helped value, but a plain jane 4 door 2 barrel 327 with the basic powerglide transmission has very poor value as a restoration .
i'd say clean up the body, sanding off the rust and fixing the desnt, and puut a cheap single stage enamel job or a semi-flat painr, maybe upgrade to front disc brakes to make it safer in modern traffic, tune it up or even do some engine upgrades if you like, 4 barrel carb and dual exhaust.....and just drive it as a beater rod.
As a four door It's not worth the cost of a full restoration.
might just be my opinion, as i used to buy those in the late 1980's for $500-700 or even less and part thenmout ofr the engine, trans, and what body parts would also fit 2 door and scrap the rest....I wouldn't pay more than $2k the way it sits today just for a beater driver.
Probably be worth a good bit more with hotrod stuff done to it.....because it isn't a Super Sport 2-door or even regular 2 door keeping it bone stock doesn't have any desirability.
I can understand that. I have a fram stand that rotates and if I was talked into another motor. I would prefer doing my body work from the stand anyway. I imagine the aluminum trim will be pretty easy to work out and buff I have a small anvil and tools for that and the bumpers will just get like a 4mm chrome plate.People have differing ideas of restored---I see guys spending $2000 to get their frames cleaned and powdercoated, then you have all the suspension parts, plus the cost of new wear parts there like ball joints and bushings, bearings, etc.
Chrome work is crazy expensive now, if you can find anyone to do it.
A nice interior restoration back to stock is $3000 minimum.
Wiring.
Brakes.
Engine.
Trans.
Then the paint job. In my area, most shops won't do all-over so on old cars, they only do insurance work. Specialty shops charge a minimum of $5,000 for a nice paint job. Corvette restoration guys are paying $15,000 for nice paint jobs and waiting years to get it done.
A shined up driver is nothing like a restored car, a restored car is like new, in every detail.
yeah i guess i can understand the difference in replacing everything on the car to call it "new"People have differing ideas of restored---I see guys spending $2000 to get their frames cleaned and powdercoated, then you have all the suspension parts, plus the cost of new wear parts there like ball joints and bushings, bearings, etc.
Wiring.
Brakes.
Engine.
Trans.
i dont plan on selling it ... haha not that everyone doesnt feel that way at some point...Start with what you would like to sell the car for then work backwards.
You got a good price on it out the gate. So your far ahead.
I would look at selling that for $5500 after driving it for 2 years.
I would grab a air cleaner to pan 350/383 mated to th350 or th400 off of marketplace for $800-$1000.
Have a shpp install the headliner and clean the interior for $1000.
Driveshaft and odds and ends for another $1000 as stuff will add up fast.
Then let the next guy do the rest trying to trade up for something closer to fully restored.
If I read your carb number right it’s original. Not an add on.
That’s a plus.
Here’s an almost gaurenteed negative.
I’ve had a 65 and 67 impala and neither one had a good frame. Looked good but you couldn’t jack up the car using a small hydraulic bottle jack anywhere on the frame from the front wheel to the back wheel. They were both soft enough to warrant just parting them out. Was a shame as the rest was solid and rust free.
Spend some time checking the frame. You might be surprised.
i have only 2 small spots on the doors and 4 quarter panels to reconstruct. the frame has no rust. the rocker has some blisters but nothing major the trunk lid rotted a little under its trim but its honestly not that much work. and to machine this 327 the shop i use will charge about 600 for the block , heads , rods and crank.. not 2000 trans is gonna be about 500 if it needs work at all again im not flipping this car for money ..The body work alone would be enough to send me running , to hand form all the rusted parts (wheel openings , inner & outer , door bottoms , inner & outer , rockers , inner & outer , windshield & rear glass openings , trunk & hood lips , cowl , pillar posts , etc ) on that car would take a tremendous amount of time for even an experienced body man , then the time to weld them in , wow ! Oh , have you priced body supplies ,& paint lately , there's a couple grand , easy The engine is a minimum $1500-$2000 in machining & labor , trans , another $500 , brakes , drums , shoes wheel cylinders , lines hoses & linings $??, shocks , ball joints , control arm bushings , tie rod ends . That factory air system restoration , heater core , radiator . Sorry man btdt , a couple of times on cars that were going to be worth big bucks done , you don't ever break even
You & I know where there's a bunch of those 283-327 worshipers ....LOLAnother thought....if you plan on doing any engine rebuild work, don't do the 327.....get yourself a bare 350 block and proceed to build yourself a 383 stroker. You got a big boat of a car, you need torque to get it moving and the 327 will never have that.(unless you plan to turbocharge or supercharge it)
Then sell the 327 to some idiot who still thinks the sun rises and sets with "327" and will pay you top dollar for it....and step up to some real power with the 383.
