Hi All,
Can you please help me with my carb.
It has 3 ports on the front, the Timed port (passenger side), PCV port (middle), and Manifold port (drivers side).
When a vacuum gauge is used, the Manifold port is acting the same as the Timed port, WHY???
Both have no vacuum at idle, and then increase the same amount as the revs are increased.
The PCV port has a vacuum of 16 at idle and increases as the revs increase, as you would expect.
From looking at Youtube videos, I thought the Manifold vacuum (which is at a lower level than the Timed port)
was supposed to have vacuum at idle and decrease as the revs are increased. But its not.
Can you please help me understand what's happening. Is this normal for this carb, surely not!
Many thanks,
Jack
Many thanks,
Jack
