first of all if it was my 68 I would put in a shaft style radio with cd changer combo. that way the dash will still be in tack.
But if you are really set on cutting up the dash you will need a few tools.
first a saws all and a drimal with cutting blade.
and a good flat file. Now to insure you are not doing this in vain measure the depth of the cd player you are wanting to install (remember not all cd players are the same size)then measure the location you want to install the unit.
if you have enough room then get a template of the cage for the unit and mark it out where you want it installed at.
the trick is to cut on the inside of the line and then file away the differance to get that great custom fit.
after you get the cage slot finished and it fits
tight then the rest is just installing the cd player.
if you need any more help just drop me a line
