Hi All,
I just finished the T5 manual transplant into my 83 Olds wagon. Originally had a th350. Then a 2004r, now a stick! I used a new Centerforce Dual friction clutch, new throwout, surfaced flywheel, finally got the hydraulic master and slave setup, man was that a nightmare! The whole setup was from a 92 Camaro. Anyways, Centerforce says their clutch, Dual Friction, requires a 400-500 mile break-in. Daily driving, stop and go, no full throttle shifts! I just took the car for its first road test. OH man am I going to like driving a stick again!!! It's been so long! It went pretty well except for the clutch will slip if I put my foot into it past 1/3 throttle. I am making about 330hp from a mildly built 350. Nothing crazy with the motor. 3.73 posi in the back with street rubber. I only put maybe 20 miles on the new setup. I didn't floor it or smoke the clutch or anything like that but I can definitely hear and see the tach move, and I can tell its slipping when I get into it a bit. It gets worse and I go up in gears and lower the revs. 5th gears will really slip if I am doing anything else than idle a 35 mph. Is this normal for such a new clutch??? I know these things have to wear together but considering its supposed to have 90% more holding power I didn't think this would happen. I have no play in the clutch pedal or in the fork either. I know the hydraulic setup is self adjusting but should there be any play at all? Right now there isn't. The clutch starts to grab with about 2 inch's to an 1 1/2 inch left of travel when I let the pedal out. I am assuming that this is about normal.
Any comments would be great!
Zeder
Zeder
