I'm thinking of maybe changing from carb to Holley or Fitech EFI.
I know that changing from dual to single plane intake reduce the bottom end hp and increase top end hp.
Does this happen in the same amount, if I change to EFI at he same time?
Or is the EFI system able to keep the low end power better that what the carb would have done?
Engine is a 380 hp Chevy Small block with Vortec heads.
Intake is an Edelbrock RPM AirGap Dual plane.
Car is a 34 Ford Roadster. Manual trans.
