1) If i were to switch from basic cast pistons(non-hypereutectic) to forged, would i need to do anything to the cylinder walls (assuming the walls are ok)? Can i just "pop" them in there, so to speak?
2) i want to eventually return the engine to the street (it's track-only for now), so is there a forged piston that will "act" like a cast piston?
a) OR would a hypereutectic piston work and be a good compromise if i want to run no more than 7-8lbs of boost.
b) Would the stock cast pistons work at 7-8 lbs, IF i'm very careful with the tune? i'm even willing to run E85 as it's track only for now.
Engine is:
---262 cid 90 degree chevy v-6, 2-bolt main, stock block
--- 9.3 to 1 compression (although, i assume with a piston change, compression could change as well)
---- cast aluminum pistons
---- target is 300hp/350tq hopefully at lower rpm vs. higher rpm as we can't spin it faster than 5600 with the stock bottom end.
---- Don't want to run anymore than 8lbs of boost, unless with forged pistons and even then no more than 12-ish because i don't want to push it with the stock bottom end. Car is light enough to run 11's with 300hp.
Engine is:
