Hello All,
I have a CJ7 and run two group 24 batteries. One is over 8 years old the other is 3. I use a basic marine 1/2/both switch to manually select them. All custom cables, all great condition and clean.
I really thought the 8 year old battery was bad and was ready to replace it but it turns out the newer battery is the bad one. Both batteries test at +12.5-7 volts but the newer battery will not crank the motor. It clicks like it it completely dead.
I have swapped cables, no different. The main wire to feed the interior/accessories is post marine switch and both batteries power the headlights etc perfect.
If new batteries weren't 200$ each i would just replace both. Anyway, have you ever had a instance where a battery show full voltage but can not deliver any amps?
chris
chris
