killerformula said:Put I mic on the back of your valve, put a 10 lb spring on it, push it down with your thumb. That way you can do it without taking the head off, if its already been put on.
K
This won't tell your valve clearance.....only your deck ht.406chevelle said:Poor mans solution.
Put a level across the deck and bring the piston up to top dead center, then use a set of feeler gages to determine how far the piston sits, then add it to your gasket thickness.
406chevelle
Right you are......my bad.k-star said:If i read the question right he wants to know how to check piston to head, not valve to piston...
Keith
