'65 el camino, stock 3 speed tranny.
once in a while, i get locked out of second, pull it back down into low, and then it will let me shift....usually. when i get under the car, the bolt holding the R/1st lever is loose, tighten it, it shifts fine for a little bit, and then same problem. what would cause that bolt to loosen up like that? anybody else have this problem, or know of a solution?
thanks.
thanks.
