Well, since no one has responded, I will give my take on the subject.
A 302 has to turn some serious RPM's to make any, real power, and would benefit greatly from a higher than normal (for todays engines) compression ratio. With that said, I believe you should shoot for zero deck height.
I wonder if the late model 265 crank is going to be able to hold up to the the RPM needed for decent power. You might want to look into an after market crank.
JA
JA
