Hey guys- I am in the process of rebuilding/building up a 307 i picked up for $100.00 that is complete from oil pan to the carb. I am going to school full time, but have decided that I want to build it up on the side and maybe throw it into a little s10 pickup from the late 80's/90's which I feel would make for a quick little toy to tinker with. I've started tearing it down and running the numbers and have found out that it has 305 heads #354434 and that the motor, due to its overall condition, could use a complete redo. I know that this motor, even after being built up, wont make horsepower that is worth bragging about but I wanted to build a 307 because it was different and the fact that I don't need 400 horses to move a something as small as an s10 pickup, but would still like to make it as aggressive as I can.These are a few of the things I would like some suggestions on from some of you guys out there who know a little more about these topics than I do...
1. Since I am shooting for a fairly aggressive motor, would I be better off finding a cheap set of 350 heads or sticking with these 305 heads since I already have them?
2. I plan on keeping everything in the bottom half of the motor (ie. crank, pistons, rods) after I clean them and install new bearings and hot tank the block. I would like to replace the stock cam with one that is more aggressive. I dont need to turn insanely high RPMs but would like a cam that sounds good and performs good for use not only in town but on the highway. What cam specifications and brand would you guys recommend with the little bit of information that I have given you in this thread?
-Thanks
-Thanks
