Hi everyone,
I have a brand new rebuilt 350 engine that I've been trying to turn on with no luck, I've narrowed it down to a compression issue. First I compression tested every cylinder and was getting 145-150psi in 6 of the cylinders and about 120psi in two others(5 and 8 to be specific). I ran a leak down test today and ran 60 psi in, and about 50psi or so was coming out(piston at tdc). I suspected I had overtightened the valves so I loosened them and then set them to the point where the pushrod has no up/down movement and then 1/2 turn more, and immediately when I do this the gauge on the leak down tester drops below 10 psi and I can hear a difference in the hissing air escaping. However, after a few minutes, the gauge will go back up to 50ish psi. If I tighten the valve another half a turn it drops back down to 10 and does the same exact thing. Could someone please help?? I'm so confused, I am now overtightening the valve and opening it but it seems the pressure keeps dropping? Doesn't make sense to me.
PS everything on the heads(rockers,lifters, pushrods) are new and I had the heads (and block) brought to the machine shop where the guy said he had fixed them up. Seems to me like something is wrong with the valves?
