Ignition condensers are high probability failure items.
It's an 85 GMC c2500. When I took the original engine out, I took pictures of most of the wiring and so just rewired everything the same. I Think that is all set up correctly?What vehicle, so we know what/how the wire routing and circuits are laid out??
you mentioned condenser....is it a points distributor??
The three groove gear really isn’t enough to mess the engine up as much as you seem to have on your hands. This is just a tuning adjustment that moves the cam a little to favor more mid range torque through the factory standard position to a position that favors top end horsepower. The changes are rather subtle almost mot enough to perceive without a dyno as it’s more a global shift of the torque and power curves around a fixed reference point, that being the factory position.Hey guys,
Checked spark plugs, they all look goodI also double checked any plugged holes into the intake manifold, so I think we can rule out extra air getting in.. will flip the distributor 180 tomorrow just to see and also advance/retard ignition timing again, but I'm thinking that the internal cam/crank timing must be off. When I try to turn it on it's still backfiring gas out of the carb and has combusted it a few times. Its a 3 keyhole crank sprocket and I'm preeettyyyy positive I put it on the key on the standard timing alignment and aligned the two circles properly, but maybe not? Or the timing chain slipped? Like I said im kind of at a loss, about to start searching for a mobile mechanic...
Hey Bogie this is originally what I had done to set the valves with no oil in the lifters I had twirled the pushrod between my fingers until it wouldn't twist anymore, and then gone 3/4 of a turn more and rotated the engine 90 degrees and checked for any loose ones. When I had read about this method it had said you shouldn't need to go more than 2 full engine rotations (4 crankshaft turns) but I had gone around 4 and was still getting semi loose pushrods, so that's why when all this first started I figured I did that method wrong and switched to adjusting lifters when the piston is at tdc.Again you need to allow time for the lifters to bleed down till the valve gets seated. The pressure testing you did a while back only tells you the lifter hasn’t bleed down. Really once you get a feel for this you don’t need to wait for the recently adjusted lifers to bleed down. Once you have the lifters for the cylinder of interest on the heel of the lobes for that cylinder all you need do is loosen the current adjustment then come back and tighten the nut while rolling the push rod between thumb and forefinger till it resists your turning. Note where your wrench is and add half a turn, move on to the next valve or on to the next cylinder in the firing order, rinse and repeat till your back to number one.
This is what everything looks like. New 650cfm carb from AutoZone and the distributor is new rotor and cap but original housing.
I think you have your valves to tight, when spinning the push rods in your fingers until tight you are pushing the plunger down in the lifter bore and don't even know it, if you are tightening the rocker nut until you can't turn it anymore you have tightened it to much, you should still be able to turn the push rod with your fingers at zero lash. How to adjust your valves. loosen up all your valves turn the engine till you have compression on #1 cylinder. Once you have it on TDC, you adjust the following valves #1,3,4,8, exhaust & #1,2,5,7, inlet. Then you turn the motor over once back to the timing mark, you are now firing on #6. You adjust #2,5,6,7, exhaust & #3,4,6,8, intake. Done. When adjusting the valves i use the up and down method with your fingers on the push rod just slightly raise the rod up and down until no more up and down you should still be able to twist the push rod, at this point tighten the rocker nut 1/2 turn only.
I think you have your valves to tight, when spinning the push rods in your fingers until tight you are pushing the plunger down in the lifter bore and don't even know it, if you are tightening the rocker nut until you can't turn it anymore you have tightened it to much, you should still be able to turn the push rod with your fingers at zero lash. How to adjust your valves. loosen up all your valves turn the engine till you have compression on #1 cylinder. Once you have it on TDC, you adjust the following valves #1,3,4,8, exhaust & #1,2,5,7, inlet. Then you turn the motor over once back to the timing mark, you are now firing on #6. You adjust #2,5,6,7, exhaust & #3,4,6,8, intake. Done. When adjusting the valves i use the up and down method with your fingers on the push rod just slightly raise the rod up and down until no more up and down you should still be able to twist the push rod, at this point tighten the rocker nut 1/2 turn only.Hey Bogie this is originally what I had done to set the valves with no oil in the lifters I had twirled the pushrod between my fingers until it wouldn't twist anymore, and then gone 3/4 of a turn more and rotated the engine 90 degrees and checked for any loose ones. When I had read about this method it had said you shouldn't need to go more than 2 full engine rotations (4 crankshaft turns) but I had gone around 4 and was still getting semi loose pushrods, so that's why when all this first started I figured I did that method wrong and switched to adjusting lifters when the piston is at tdc.
I,m Sure you also triple checked your plug wires?Hey Jay,
Yeah what I was saying is what I had done originally, what I changed after is as you are saying I moved the pushrod up/down as I tightened it until no up/down movement (with the piston at tdc compression) and then went 1/2 turn more. Still getting backfire out of the carb, so I'm thinking it must be off a tooth or two. Going to open up the timing cover and take a look today, I'll let everyone know what I find.
