I've just installed a 350 crate engine in my '69 pick up. Timing is at 8 degrees without vaccuum advanced hooked and plugged off. with it hooked up it is about 1/2" passed the timing marks, putting it around 14 to 16. wires are brand new and in correct order, with the very least amount of crossing near the cap. None touching each other. rest set idle and carb screws are at 2 1/2 turns out. Exhaust is very short, comes out right behind the cab for now. Running electronic ignition and the quadra jet carb. Need help because I do not want to blow another engine for possible timing issues. Any help or ideas are appreciated.
Thanks,
Strays
Thanks,
Strays
