I have a standard Chevy 350 with a 4 barrel carb in my 81 Corvette. Total miles about 87K. The carb and associated components have worked fine, kept clean never needed service. Car is garaged. Problem: Once the electronic choke opens up, the engine rpm drops to a lower value as usual. When I tap the accelerator to drop it further down to normal rpm, the engine quits as the choke light illuminates. I recently replaced the fuel pump and fuel pressure output from the pump appears normal. Thanks for your suggestions. Cp
