I just picked up a 4.3 that I am hoping to put into my well used '92 GMC Safari (305,000km). The guy I got the motor from claims it only has 60,000km on it. The block casting number is 10227196 '93-'94 balance shaft, throttle body.
The questions that I have are:
1). Will the flywheeled motor be balanced for a flex plate? Are the two interchangeable without ANY shaking? If so, can I use the flexplate that is already in the Safari?
2). Will the the wiring harness connections to the motor be the same between the two?
3). Can I use the '92 computer or should I get a '93,'94 computer?
I need this thing to pass emissions as well.
Thanks in advance.
J.
Thanks in advance.
J.
