ok, so here it goes. back in march of this year my dads 1994 chevy K2500 with a 6.5 turbo diesel cracked a piston. so we yanked the engine and had it completley rebuilt with a rebuild kit from diesel direct, and had all the machine work done by Polk Diesel in Madison. they also magnafluxed and pressure tested the block. we checked all the clearances with plastigauge, and buttoned the enigne back up. after we got it back into the truck, we fired it up and it ran really good, but then it lost oil pressure and shut it off. At first we though that we had a bad sending unit, so we replaced that, but that didnt solve the problem. next we replaced the oil pump and pickup screen but the problem continued. we also replaced the oil cooler lines and made sure that the oil cooler was free flowing. after all that, it just sorta sat int he garage during summer and fall. then this christmas break my dad decided to pull the engine back out again, and see if we couldent find the problem. we looked at the bearing to make sure that they where ok, and checked the tolerances again, and they where within specs. while cleaning out the oil pan my dad found a welch plug that goes into on of the oil passages. so he ordered the part and decided to put in the new one, and then, put one more in on top of it so it would never come out. so after all that hassle, we put the engine back in, hooked it all back up, and fired her up. At first the oil pressure was at 40 psi, but then it slowly dropped over the next 4 or 5 minutes to reading no oil pressure. before we replaced the plug the lifters had bled down and began knocking, but this time they knocked just a little bit until it stopped and sounded really healthy, even when reading zero oil pressure. Also if you disconnect the oil feed line to the turdocharger before we did not have any oil flowing, but this time, we have a nice high volume stream. we also verified that all the passages in the engine block where free flowing, and that no assembly lube had gotten stuck in a passage or somthing. also, we replaced the oil, and oil filter after the inital startup. the dealer suggested that teh bolt that holds on the oil pump may be too long and could restrict oil from passing through, but after ordering the part and comparing it to the bolt that was in there holding the pump in, they are both the same. It dosent make any cense that we would have oiil off the turbo feed line, if we didnt have any oil pressure, and it runs too well this time to not have oil pressure. has any one got some suggestions????
thanks,
Jordan
thanks,
Jordan
