CAR:1989 Cadillac El Dorado
Engine: 4.5L Alum V8 Dfi
Drive: Fwd
Problem: It all started After I used Some gas from a Gerry Can, Assuming it had water in it i used water remover before i drove it anywhere. I bearly drove 10 feet when it began dieing so naturally i nailed the throttle, revving it to approx 2,200 rpm, then letting it idle down and it died. So i was like well maybe my injectors are dirty or something, so i cleaned the carb and put fi cleaner in the tank, And started it again. Now i cant even put it in gear with out it ding , never mind keeping a charge on the battery. So whats happening? It has back fired a alot, there is alot of pale type exaust comming out witch makes my think its burning lean, but when i looked at the fuel flow from the injectors it seems to be getting allmost too much fuel? I doesnt idle more than 30 seconds before dieng out the only way to keep it running is by mashing the throttle up to 2,000+ rpm. My battery holds 11.8 and charges at 12.4, so my battery is ok, and i think the gas was premium for my brother go kart, and like i said i used water remover to be safe and injector cleaner. It never ran * before that , i had the cat remover since it was from california originally and i put a new pipe in there. It ran good still, i drove it for about 2 weeks solid,a nd then i parked it with a dead battery from listenign to the sterio i had installed. So about a month later, when we decided to move i began to charge the battery, it it was no good so i went and bought a new one, goo fired up on turn key...
So a 2 weeks later the whole gerry can thing happened and now it dont run at all. i have removed the spring to see it the idler arm was loose but it seemed fine and the electric idle/choke deal was ok, i did a small adjustment to see if i could even get it to idle but no there no hope in that, so i returned it to where it was and it has never been the same, and after my battery dying several more times and killing a few other poeples from boosting i have decided to seek help. can anyone help me at all?
Also my cpu is telling me i have a cooling fan fault what causes this? its a new rad and fan setup and when i turn the ac off since i have no charge, it stops?
Thanks
Drive: Fwd
Thanks
