Hello to All with Knowledge as I am looking for guidance or a recommendation to improve the shifting on my 63 Chevy C10 that is a frame off restoration built on the Frame and Transmission of a 72 Blazer 4 x 4 (Muncie SM465). This truck is a real head-turner but not a joy to drive due to this Tranny / Shifting Options. I have looked for Shift Kits as I don't think any are available.
Would you recommend a conversion to THM 400 or TH 700R4? The Motor is a Crate 350.
Thanks,
Dennis W. Parks
Personally, I would go with the 700R4 since it gives you the overdrive, which will save you some gas money when on the highway. Unless of course, you are using this strictly as a four wheel drive vehicle. If this is indeed a street vehicle and a relatively stock 350 engine, a TH 350 would be ample and probably a better bet than the TH400. If the horsepower goes up, the TH400 tranny might be more desireable.
Regarding the 700R4, make sure, and this is a must, make sure that the tranny lockup and vacuum are properly clocked to the carburetor if you are using a carb. Most 700R4 trannies were paired with fuel injected vehicles, so it was not a problem. But, if using a carb and it is not set up correctly, you will burn up the tranny in a hurry.
Hope this helps,
Dennis W. Parks
Author of automotive how-to books
68 Pontrolet
Are you tired of shifting or tired of the way the 465 shifts? It you want to keep on shifting, have you considered an NV3500 or 4500? Haven't looked at all the fitment requirements, but you could keep granny and have an overdrive with less fabrication.
The trick with the 700R4 is getting the TV cable set up properly. The TV cable controls the line pressure and like WriterDennis said, you can burn the trans up pretty quick if you don't have it right. Several companies sell kits to help you do this ($100-$150). For the lock up, you can run it to a toggle switch for easy set up.
The TH400 will probably be the cheapest considering you'll need some extras for the other options.
Can you tell us what engine year/tq/ and intended (ab)use?
