everything fits right, length, diameter, but why is the pin/hook coming out of the transmission too big to slide up in the sleeve the cable goes up into? does the pin/hook not need to be able to travel into the sleeve to function?
i tried another one for the same year diff serial # first and the hole at the tv cable was too small so i bored it to fit and the pin/hook slid freely into the sleeve but the sleeve was too big for the mount hole on the side of the trans.
I wonder if the wire link in the trans is bent or the incorrect wire.
the cable end problem , sounds like the wrong cable was tested if the diameter is too large to fit into the case hole.
Rod...from a Chrysler?
I think you need a new detent cable.
If you have to bend something to make it work, you're asking for trouble. :pain:
