Check out Jeep vehicles.. Sorry I don't remember part no. I used to use the clamps on str axle fronts. They are retained on the split ends of Jeep shaft by toothed/shake proof washers;)
Hey,
I think, you can check out from CNC machined from 1020 DOM material and zinc plated from maximum corrosion resistance, the Synergy Suspension Tie Rod Clamp is compatible with the Synergy Suspension & Fox monotube steering stabilizers. Thanks..
________________________________
Have a look at: wire grommets | nylon fasteners
