Class 5 hitch : any body here used them? The truck I am looking at have 2.5 inch receiver hitch on them
The insert design that is a dropped hitch. Dual ball style. 2.5 inch square receiver on the truck.
I see 10k tow weight ratings to 20k ratings on them. Material thickness is heavier with higher weight rating. Some of these inserts are listed at nearly 50 pounds of weight
I have never used one. They all seem to function basically the same. Pull pins to move the ball height location up or down. Pull another pin to rotate from 2 inch ball to 2 5/16 ball.
I see prices from 200 dollars to 500 dollars. Seem to be all steel or aluminum and steel materials used on these
