i pressure washed my block w/ crank,rod,pistons in, and used simple green on it to degrease it to paint the block. it is now painted, and i am ready to put a cam/heads/pan, etc on it. how can i clean the innards of the block before i assemble it. after i pressure washed it, i tried to blow away as much water as possible, then i sprayed it with WD-40. but there is still some water in there, and im sure theres more dust and debris.
also, how can i turn the crank over? i have the harmonic balancer bolt, but is it ok to use it to turn the engine, because it will bottom out without the balancer right?
Thanks,
Jerome
Thanks,
Jerome
