I'm trying to learn a little more about ignition coils, I recently purchased a brand new crane cams hi-6 cd ignition and a crane cams lx91 coil wich is the recomended coil to run with the hi-6 on the street. I have a 300hp crate 360 magnum engine with my initial timing set at 15 degrees and total timing set at 33 degrees and i have an additional 10 degrees of timing added to the 15 degrees of initial timing at idle from my vaccum advance being on manifold vaccum.
I run 91 octane fuel and i live 4000 feet above sea level and the plugs i am running are champion rc12yc factory plugs for the 360 magnums from 94 to 98 i believe, anyways i am trying to determine what gap to run, i tried .045 and it ran better then it did with the stock .035 gap, then i tried .050 and i think it ran even better at .050, but i have been told .050 may be too large.
So i decided to do some research on my coil to try and find out whats going on with my spark and got confused...
i dont know if i have a hotter spark or a faster spark or what but here is what i was able to find out about my coil. Primary resistance is 0.420 ohms, secondary resistance is 3.5k ohms, turns ratio is 54:1, inductance is 5.6mh, peak current is 100ma and spark duration is 2,800 us. So with this information, does this mean i have a coil that puts hot a good hot spark? or faster sparks? Crane claims the 54:1 turns ratio brings great spark gap current? Does that mean this coil can fire a plug with a bigger gap? And with my set up would .050 be an ok gap with my ignition and coil and engine? I forgot to add the compression ratio of my engine is 9:0.1. I'm just trying to determine the best gap to run, i have tried .045 and .050 and .050 felt the best to me, but others tell me thats too big of a gap. So please help me figure out if .045 is where i need to be or if .050 would be fine.
