1 - 7 of 7 Posts
How can I tell the spring rating? I would like to order some stiffer coil overs, but I'm not sure what my current ones are.
Most sprngs have a small metal tag attached to a coil near one end of the spring with the spring rate stamped onto it. You might try looking for such a tag at the top or bottom of the sping.
John
Spring Rate ID
You didn't mention the brand but if you happen to have Aldans the springs are identified by a painted color band on the end of the spring. Naturally that means you have to disassemble the coil from the shock to see it. I don't recall the colors but I'm fairly certain that a green band is a 180LB spring. There's black, red and some others. Check Aldan's website.
If they're not Aldans...sorry, can't help ya.
Hotrodders.com moderator
Springs are rated in lbs/inch..soooo if one puts a known weight on the spring to compress it one inch you now know the rate..They do make spring rate checkers as well if you like..
Sam
Race it, Don't rice it!
Use a spring rate calulator I've posted on here before.
You need the wire diameter, the number of active coils, and the overall diameter of the spring center to center.
It'll go, or it'll blow...
To get the actual rate of a spring is easy if you have a hydraulic press and a bathroom scale.
Place scale on press. Place spring on scale. Zero scale. Compress the spring an inch and read the scale. This gives you the spring rate (lbs/ inch.)
Be careful centering and lining up the spring so it doesn't fly out!
Works good for most low rate ~<300 lb/inch springs
Philippines Cowboy
I searched for your calculator, johnsongrass1, but couldn't find it. Here's the relationship I use:
rate = Gd^4/[8n(D-d)^3]
where G = 1.16E7 , "n" is the number of active coils, "D" is the outside diameter, and "d" is the wire diameter.
1 - 7 of 7 Posts
