1 - 6 of 6 Posts
I have a 1955 F100 running a 390 FE with MEI dizzy and electronic coil, which is mounted on the front of the motor. I'd like to mount it on the inner wing but that means the coil wire would be 600mm long. Would that cause a problem with voltage drop.
Thanks in advance.
Thanks in advance.
If it worries you go one wire size larger, ie if it's 16 gauge use 14 gauge, and that will work.
1 - 6 of 6 Posts
